Cartridges for Indexable-Insert Drills and Boring Heads
June 01, 2016
The new rectangular cartridges from E-Z Burr Tool are a custom-made solution for indexable drills and adjustable precision boring heads. Now you can accomplish two operations in one convenient pass. The company simply mills a trench in an indexable drill or boring head and installs a custom-designed deburring cartridge that slides right into the trench. The cartridge has the same patented E-Z Burr performance features that are consistent with its highest-quality carbide series tools.
The company can work with end users to have the proper modification made to an existing drill or boring head to allow these cartridges to drop right in.
E-Z Burr currently supplies these cartridges to several large customers, including a large excavation machinery company, a major truck wheel maker and a steel mill.
  • boring
    boring
  • boring head
    boring head
    Single- or multiple-point precision tool used to bring an existing hole within dimensional tolerance. The head attaches to a standard toolholder and a mechanism permits fine adjustments to be made to the head within a diameter range.
  • burr
    burr
  • milling machine ( mill)
PRODUCTS
11/20/2024
10/23/2024
10/23/2024
