CB6 Walk/Ride Transport Base
Move a sump cleaner safely through plant between collection, treatment or disposal with CB6 walk/ride transport base from CECOR. Sump cleaner is mounted on a battery-powered pallet truck with stand-on platform for easy driving.
Move a sump cleaner safely through plant between collection, treatment or disposal with CB6 walk/ride transport base. Sump cleaner is mounted on a battery-powered pallet truck with stand on platform for easy driving.
Off the truck, operator can use controls to maneuver unit into tight spots and next to machine tools for sump cleaning. Sump cleaner uses high suction lift to remove coolant, chips and sludge from sump. Solids are caught in patented CECOR filter, while coolant passes into the tank. Operator can then drive unit to reclamation or disposal station.
The CB6 walk/ride pallet truck operates on a 24-volt battery. With a tight turning radius, the pallet truck maneuvers through narrow aisles and around tight corners. The base has a battery charge indicator and automatic charger. It also features a high-tech speed controller with adjustable acceleration/braking.
