Cermet WEP10 Indexable Turning Inserts
The new Cermet WEP10 indexable turning inserts from Walter deliver long tool life and high productivity. Their fine-grain titanium carbide substrate with Ni/Co binder produces a stable cutting edge. Combined with an extremely hard TiCN outer layer, this grade provides multiple advantages during finishing operations when compared to carbide inserts.
These advantages include increased tool life due to its high wear resistance, no necessity for readjustments, and maximum dimensional accuracy. In addition, Cermet WEP10’s FP4 soft-cutting insert geometry is suitable for finishing a range of different materials. The FP4 geometry, with its unique edge preparation is capable of yielding mirror finish surfaces at high or low cutting speeds. A variety of insert shapes are available.
Application areas for the new Walter Cermet WEP10 include finishing operations with continuous or slightly interrupted cut in steels, stainless steels and cast-iron workpieces. Targeted industries can be general metalworking, mechanical engineering, energy and the automotive industries.
  • edge preparation
    edge preparation
    Conditioning of the cutting edge, such as a honing or chamfering, to make it stronger and less susceptible to chipping. A chamfer is a bevel on the tool’s cutting edge; the angle is measured from the cutting face downward and generally varies from 25° to 45°. Honing is the process of rounding or blunting the cutting edge with abrasives, either manually or mechanically.
  • interrupted cut
    interrupted cut
    Cutting tool repeatedly enters and exits the work. Subjects tool to shock loading, making tool toughness, impact strength and flexibility vital. Closely associated with milling operations. See shock loading.
  • metalworking
    metalworking
  • stainless steels
    stainless steels
  • titanium carbide ( TiC)
    Extremely hard material added to tungsten carbide to reduce cratering and built-up edge. Also used as a tool coating. See coated tools.
  • titanium carbonitride ( TiCN)
    Often used as a tool coating. See coated tools.
  • turning
  • wear resistance
    wear resistance
