Chamfer Mill Covers Entire Material Spectrum
The MicroCut F miniature chamfer milling cutter from Denitool Inc. is for tube-end treatment and chamfering of small- to medium-size threads and countersinks. It is suitable for bore diameters as small as 2mm (0.079") in diameter.
July 19, 2017
The chamfer mill has a Weldon shank and hardened insert pocket. The FW 1108 RSDS-06 cutter has through-coolant capability.
  • milling cutter
  • chamfering
