Cimclean 30 and Producto MC 321
Shop supervisors around the world turn to Cimcool Fluid Technology for effective and affordable cleaning products designed to keep metalworking operations at peak performance.
Shop supervisors around the world turn to Cimcool Fluid Technology for effective and affordable cleaning products designed to keep metalworking operations at peak performance. CIMCLEAN 30 is for eliminating shop waste, metal swarf, oil, mold and bacteria in the most difficult manufacturing environments. PRODUCTO MC-321, an industrial strength water-based general purpose maintenance cleaner, removes grease, oil and dirt from machinery, floors, walls and other hard surfaces. The products are manufactured by Cimcool.
CIMCLEAN 30 is a general-purpose cleaner concentrate specially-designed for use on individual machine and central system reservoirs, metalworking fluid lines, premix tanks, machines and parts. It effectively removes bio-films, dirt, grit, chip deposits, insoluble soaps, and oils from central systems and individual machine sumps, and contains corrosion inhibitors to protect machines and parts from rusting during the cleaning process. Like the rest of CIMCLEAN's extensive line of products, CIMCLEAN 30 is available in mildly alkaline or highly alkaline solutions, easy to use, versatile and appropriate for washers, spray, dip tanks, or ultrasonic applications.
In at least one shop setting, CIMCLEAN products were tested against competitors' brands for cleaning stainless steel and carbon steel fuel injection parts. CIMCLEAN reportedly washed the parts better and left little, if any residue. By using CIMCLEAN products, the customer cut cleaning fluid usage in half, resulting in an annual savings of more than $300,000.
CIMCOOL also offers PRODUCTO MC-321, an industrial strength water-based general purpose maintenance cleaner designed to remove grease, oil and dirt from machinery, floors, walls and other hard surfaces. The versatile PRODUCTO MC-321 can be used in dip/immersion tanks, ultrasonic, low-pressure spray and spray and wipe applications. It cleans without agitation, has excellent rinsing properties, can be diluted with water in any proportion depending on the severity of the cleaning, and will not clog cleaning equipment even at high concentrations.
