Cimperial 1072-HFP
Cimperial 1072-HFP
Cimperial 1072-HFP is a single fluid recommended for all metals and all heavy-duty machining operations including turning, drilling, tapping, reaming, gear cutting and broaching.
August 1, 2011
Cimperial 1072-HFP is a single fluid recommended for all metals and all heavy-duty machining operations including turning, drilling, tapping, reaming, gear cutting and broaching. The product was developed for use in high fluid pressure applications by CIMCOOL Fluid Technology, a leading global supplier of the most technologically advanced fluids available for use in many industrial operations.
CIMCOOL's HFP family of fluids, including Cimperial1072-HFP prevent, control and reduce foam even when fluids are used in high pressure delivery systems, including through-the-tool. In addition, Cimperial 1072-HFP reportedly provides excellent lubricity; extends fluid life with excellent biological control; is operator and machine friendly; and helps prevent in-process corrosion on parts and machine components. The combination of effective performance and low maintenance contributes to higher metalworking productivity.
