Cimperial 1072D
Cimperial 1072D
CIMCOOL Fluid Technology has introduced CIMPERIAL 1072D, a soluble oil recommended for machining and grinding operations with poor water quality.
CIMCOOL Fluid Technology has introduced CIMPERIAL 1072D, a soluble oil recommended for machining and grinding operations with poor water quality. CIMPERIAL 1072D can be used in heavy to severe duty machining and grinding operations on mild steels, stainless steels, hardened steels, exotics and most aluminum alloys, including MIC 6.
The fluid has a good mix stability in high hardness, high sulfate, and high chloride water conditions. The extreme pressure lubricant provides excellent lubricity which extends tool and wheel life while providing superior part quality.
