CL-900 Fiber Laser
CL-900 Fiber Laser
Cincinnati Inc. expands its laser cutting product line with introduction of the CL-900 series fiber laser cutting systems.
April 1, 2011
Cincinnati Inc. expands its laser cutting product line with introduction of the CL-900 series fiber laser cutting systems. The CL-900 series combines the low operating cost of fiber laser technology with the company's high-performance 12,000 ipm linear-motor axis drives to create the most productive, economical and easy-to-use laser cutting system available for sheet metal processing.
The CL-900 series cuts mild steel two to three times faster than conventional lasers, while reducing operating costs by up to 40 percent. The solid state fiber laser cuts maintenance costs associated with conventional CO2 lasers by eliminating laser gas, internal optics, glassware, blowers and vacuum pumps. Also, fiber lasers deliver the beam via a flexible glass fiber, thereby eliminating the external mirrors, bellows and beam purge gas needed with CO2 lasers.
Fiber laser systems deliver power efficiency greater than 30 percent, roughly five times higher than CO2 systems. According to Cincinnati Incorporated, fiber lasers concentrate more energy into the cutting spot, allowing more agile, higher-quality cutting at higher efficiencies, and making fiber lasers ideal for high-volume cutting of intricate shapes and part designs.
CL-900 series laser cutting systems are available with bed sizes of 5 ft. x 10 ft. and 6 ft. x 12 ft. The PC-based HMI control comes standard with Cincinnati's Programming and Nesting Software to optimize machine performance, and is available with a web cam for easy monitoring of the cutting process. Cincinnati provides factory-based training on all laser cutting systems to ensure ease of operation.
