DESTACO is pleased to announce the availability of Cobot Tooling Solutions that are designed to simplify tool selection and eliminate integration design work for applications employing small payload robots or cobots in their operations. The wide variety of tooling solutions is designed for gripping, palletizing, machine tending, tool changing, and tool extension applications up to 10 kg payloads.
“Small payload robots are commonly found in larger industrial-manufacturing facilities, but there has been significant growth recently in their use in small light industrial and commercial shops due to the low-cost entry into robotic automation,” said Gary Labadie, Global Product Director for DESTACO. “This low cost entry into robotic automation is now a focus and a solution for both large and small facilities coping with the economic climate.”
The fast growth in the cobot market is driven by a number of factors, including increases in inflation rates, labor costs, labor shortages and excessive workforce turnover. The low startup costs for new entrants into the automation industry and a relatively compact return on investment (ROI) period for a cobot system, which can be as few as 8 to 12 months make DESTACO tooling solutions attractive to users.
DESTACO has designed its cobot tooling solutions for simplicity and ease of use with off-the-shelf availability via kits that feature all of the end-user selected accessories, along with the hardware and tools needed for installation, reducing the need to consult an application engineer. All of the tooling solutions are compatible with cobots that have an ISO 9409-1-50-4-M6 end-of-arm mounting pattern. Blank robot and tool plates are offered for those who wish to use their own mounting patterns.
A standout feature in DESTACO’s suite of cobot tooling is the Microtool End Effectors that enable the cobot to perform palletizing functions. Users that know the length, width and weight of the packages to be lifted and transferred can easily select the palletizing kit type and pre-determined vacuum cup size necessary for the application eliminating tool design work with off-the-shelf kits.
- payload ( workload)
payload ( workload)
Maximum load that the robot can handle safely.
