COMP V3
COMP V3
Heule Tool introduced the COMP V3 that is specifically engineered to perform multiple drilling and countersinking operations on uneven surfaces with precision, and without marking the workpiece.
April 23, 2025
The adjustable tool can be used for drilling and countersinking or countersinking only; it enhances productivity by eliminating the inconsistency associated with manual countersinking and saves significant cycle time.
The company says that a non-rotational contact foot prevents any marking of the workpiece during operation, making it ideal for super critical finishes. This unique tool offers fine adjustments to the chamfer depth of 0.0008" (0.02mm), and a drill depth of up to 2xd with through coolant capabilities.
The Heule COMP V3 produces clean, precise countersinks in a variety of materials including aluminum, titanium, and composites, making it ideal for critical aircraft components like seat rails, floorboards, structural components, aluminum wheels, and high-value aluminum castings.
It features double compensation technology for precision and finer adjustments; the contact ring compresses as the hole is drilled, and then the contact ring holder compresses after the predetermined countersink depth is reached. This technology allows a variant of part of +/- 3.75mm with height increments of + .02mm is ideal for aerospace applications and others where super critical finishes are required.
For more information on the Heule COMP V3 technology, click here.
  • countersinking
    Cutting a beveled edge at the entrance of a hole so a screw head sits flush with the workpiece surface.
  • countersink
    Tool that cuts a sloped depression at the top of a hole to permit a screw head or other object to rest flush with the surface of the workpiece.
