Carr Lane Roemheld's new compact clamp, which has a metallic wiper edge, is especially suited for applications where space is limited. Two different clamping levers are available, which can be machined to adapt to your workpiece, then swiveled into small recesses for unimpeded loading and unloading.
Four different sizes of the clamp are available, each with a short or long clamping arm.
- wiper
wiper
