Concentric Outside Diameter Clamping Tool
Mitee-Bite Products completed the design and development of a new style concentric outside diameter (OD) clamping tool. Repeats within tenths, compact for high-density application and tough enough to limit yourself to tooling capabilities.
January 21, 2020
This patent pending design can be machined to hold any shape completely through the clamp and fixture plate, as well as gripping workpiece above compression nut. This allows for OP1 and OP2+ to be run on same OD clamp.
