Coocut S-50 Soluble Cutting Fluid
Walter Surface Technologies continues to enhance manufacturing and machining productivity with the release of its new Coolcut S-50 soluble cutting fluid. Relying on Coolcut S-50 will help heavy machining and manufacturing cut down on production time, which in turn helps them reduce costs and downtime, according to the company.
The cutting fluid provides excellent corrosion protection and is safe to use and will not irritate the skin. Metal manufacturers can use Coolcut S-50 across the shop floor for a variety of applications, including drilling, milling, reaming, sawing and turning, and in higher-pressure machining processes.
