CoroMill Plura
CoroMill Plura
Sandvik Coromant introduces a new range of small CoroMill Plura ball nose end mills for profiling in medium hard to hard steels.
March 1, 2011
Sandvik Coromant introduces a new range of small CoroMill Plura ball nose end mills for profiling in medium hard to hard steels. The end mills come in diameters from 0.1 -12mm and are suited for all small die and mold, electronic fiber optic connector and medical tooth implant manufacture, where high precision is important.
Produced in a fine grained solid carbide grade with multi-layered PVD coating, the tools have a geometry design which prevents the radius from deteriorating from uneven wear. The long neck of the tool allows for good accessibility, especially in pocket milling.
