CUT 200 Wire EDM
CUT 200 Wire EDM
GF AgieCharmilles says its CUT 200 Wire EDM provides faster spark-to-spark wire threading, increases energy efficiency and boosts productivity when cutting parts of variable heights.
June 1, 2011
GF AgieCharmilles says its CUT 200 Wire EDM provides faster spark-to-spark wire threading, increases energy efficiency and boosts productivity when cutting parts of variable heights. The machine also offers higher flexibility through its ability to reliably hold tolerances measured inµm over a wide range of part sizes.
The CUT 200 integrates GF AgieCharmilles' Power Expert smart module, which continuously calculates part thickness, checking flushing pressure and adjusting machine power accordingly. This prevents wire breakage when changing the part thickness being machined. The machine also offers an optional Renishaw touch probe that allows users to inspect finished parts while still on the worktable in the machine, eliminating the need for part inspection with a CMM.
The CUT 200 accommodates wire diameters ranging from 0.07mm to 0.33mm and can handle part tapers of up to 45 degrees, regardless of part thickness. The machine's digital CC generator enables surface finishes as fine as Ra 0.1µm and an optional power module can boost cutting speed to 37.2 in2/hr. Additionally, the Econowatt 2 smart module provides energy savings by allowing operators to define conditions in which the machine will automatically shut down or awaken to complete thermal stabilization prior to production.
  • cutting speed
  • wire EDM
