D4120 Indexable Insert Drill
Walter has introduced the D4120, an indexable insert drill, (with up to 5 x Dc) that combines superior performance, enhanced precision and cost-effectiveness due to Walter's technological advancements.
May 28, 2019
The drill's list of features begins with a design that facilitates easy chip removal, process reliability and close hole tolerance through hardened and polished flute surfaces. Good finished surface quality and hole tolerance is achieved through a wiper cutting edge on the periphery insert, optimized chip flute design with continuous chip evacuation, as well as a coolant-through system (one per cutting edge) for improved cooling and fast chip removal.
Cutting costs are kept lower because of four cutting edges and the long tool life characteristics provided by Tiger·tec Silver grades. The versatile D4120, which employs inserts from the P484 family, is suitable for ISO material groups P, M, K, N, S in all major industries.
  • indexable insert
    Replaceable tool that clamps into a tool body, drill, mill or other cutter body designed to accommodate inserts. Most inserts are made of cemented carbide. Often they are coated wi…
