DA110 Perform Drill
October 01, 2018
DA110 Perform Drill
The DA110 Perform drill from Walter can be used universally and cost-effectively for a wide range of materials. It delivers maximum accuracy thanks to its precision-ground surfaces and a tip geometry that has been engineered for optimum centering accuracy, while keeping production costs as a primary consideration.
This HSS drill has a 118° point angle for secure centering, dimensions according to DIN 338 (jobber length), is offered in grade WZ90AJ, which includes an industry-proven TiN coating on the point, and is suitable for use on ISO material groups P, M, K, N, S, and O. The drill is available in diameters of 1-16mm with increments every 0.1 mm.
The Perform lineup of products is one of three categories to Walter tools. Perform tools are products that provide an economical solution with focused importance on price. Others in the Walter lineup include Advance, which indicates product efficiently balanced between price and performance, and Supreme, indicating the highest level of technology and performance available.
The Walter Perform line, which includes tools for milling, threading, and hole making that are designed to be exceptional performers at a lower initial cost is the new standard for small and medium batch production.
  • centering
    centering
    1. Process of locating the center of a workpiece to be mounted on centers. 2. Process of mounting the workpiece concentric to the machine spindle. See centers.
  • gang cutting ( milling)
  • high-speed steels ( HSS)
  • milling
  • point angle
    point angle
  • threading
    threading
  • titanium nitride ( TiN)
PRODUCTS
10/23/2024
10/23/2024
09/30/2024
SwiftCARB's new SUPERBEE 180° Corner Rounding Series features precision-ground surfaces that…
