![DDHM CVD Diamond-Tipped Tool System Cost-Effective Drilling and Countersinking](/sites/default/files/styles/product_image/public/product_images/csm_DDHM_Gruppe_018128d42f.jpg?itok=6GQs_DFa)
Paul Horn GmbH is proud to present DDHM, its CVD diamond-tipped tool system for cost-effective drilling and countersinking operations in solid carbides and sintered ceramics with a hardness of up to 3,000 HV. With the launch of this drilling system, HORN is further expanding its range of products for machining fully sintered carbides. With new geometries for producing precise core holes, the tool system allows machining to take place on conventional milling or turning centers. Cost-intensive and time-consuming grinding processes are no longer needed. Expensive new machinery can potentially be avoided by taking advantage of the DDHM tool system.
The DDHM system is aimed primarily at customers in the tool and die-making industries. The focus is on machining carbide punches and dies efficiently. The tool system also offers significant advantages in other areas such as the medical and aerospace sectors, the automotive industry, and punching, forging and forming technology. The diamond tools enable shorter throughput times, high surface quality, lower overall costs, greater flexibility within the production process and longer tool life. The drills can be used for producing holes in solid material to a maximum depth of ten times the diameter. The CVD-D tipped drills have a two-edged design and are available in diameters ranging from 2 mm (0.079”) to 10 mm (0.394”). All versions boast internal channels for cooling with air.
- Vickers hardness number ( HV)
Number related to the applied load and surface area of the permanent impression made by a square-based pyramidal diamond indenter having included face angles of 136º. The Vickers hardness number is a ratio of the applied load in kgf, multiplied by 1.8544, and divided by the length of diagonal squared.
- centers
centers
- ceramics
ceramics
- chemical vapor deposition ( CVD)
- conventional milling ( up milling)
Cutter rotation is opposite that of the feed at the point of contact. Chips are cut at minimal thickness at the initial engagement of the cutter’s teeth with the workpiece and increase to a maximum thickness at the end of engagement. See climb milling.
- countersinking
countersinking
Cutting a beveled edge at the entrance of a hole so a screw head sits flush with the workpiece surface.
- grinding
- hardness
hardness
- turning
