Dedicated Sliding Head Auto Lathe Tooling
February 12, 2018
ARNO dedicated sliding head auto lathe tooling offers high accuracy and reliable machining of all components, in all materials. This type of lathe often performs highly accurate machining of long, thin and often small components.
  • Through-tool-coolant holders with precise coolant straight to the cutting edge
  • Prepared for 340-bar coolant pressure
  • Shank sizes 12 x 12 and 16 x 16
  • Precise coolant flow between the insert and the swarf
  • Better tool life – possibly up to 100 percent or better
  • Cutting speeds can be increased up to 200 percent
  • Improved swarf control – even on problem materials
  • Efficient coolant of the insert cutting edge, protecting coatings, which can be deteriorate due temperature changes
  • coolant
  • lathe
    lathe
  • shank
    shank
  • swarf
    swarf
Sponsored Content
