DeHoff G560-DR2 Machine
The DeHoff G560-DR2 performs both gundrilling and reaming operations on gun barrels. After the barrels are gundrilled, a quick tooling changeover allows a pull-reaming operation to be performed using the same machine. The twin-spindle machine has a drilling capacity of 17 to 50 caliber and a slide travel of 60 inches (1,524 mm).
The G560-DR2 is part of a turnkey package of gun barrel manufacturing equipment offered by DeHoff, including machines for gundrilling, pull-reaming, button rifling, cut rifling, as well as tooling, heat treat ovens and gaging equipment.
All DeHoff machines are made in the U.S.A. and feature a cast iron drill head base with hardened and ground steel box ways, plus hand-scraped and fitted saddle, gibs and straps (versus linear guide ways and milled surfaces). This enhances vibration damping, extends tool life and improves the surface finish.
  • gundrilling
    gundrilling
    Drilling process using a self-guiding tool to produce deep, precise holes. High-pressure coolant is fed to the cutting area, usually through the gundrill’s shank.
