Diamond grinding wheels for maximum cutting and grinding
Innovative Products of America (IPA) has expanded its BrushAll line with the launch of ultra-thin Diamond Grinding & Cut-Off Wheels, as well as a new Type-27 cut-off and grinding wheel. According to the company, the wheels are built with advanced core bonding technology, and each wheel fully exposes its diamond particles for maximum cutting and grinding efficiency, while a reinforced steel core maintains shape, stability, and precision under heavy use.
Innovative Products of America (IPA) has expanded its BrushAll line with the launch of ultra-thin Diamond Grinding & Cut-Off Wheels (#8130, #8131), as well as a new Type-27 cut-off and grinding wheel (#8152).
According to the company, the wheels are built with advanced core bonding technology and each wheel fully exposes its diamond particles for maximum cutting and grinding efficiency, while a reinforced steel core maintains shape, stability, and precision under heavy use.
Traditional abrasive wheels wear down quickly, lose diameter, and can shatter under stress. BrushAll Diamond Cut-off and Grinding Wheels solve these problems with a solid steel core that allows users to cut areas that cannot be accessed with traditional abrasives.
"These wheels are built for professionals who are tired of burning through disposable abrasives," said Ian Vinci, president of IPA. "They cut faster, run cooler, and hold their edge longer—saving time and money".
