Diamont 42 SY2B
Diamont 42 SY2B
The patented 12 position mill/turn servo turret of the Diamont from Eurotech Elite has twelve live tool stations, four of which are capable of 360 degrees B axis rotation, to machine parts in the main or sub spindle.
May 1, 2011
May 2011 — The patented 12 position mill/turn servo turret of the Diamont from Eurotech Elite has twelve live tool stations, four of which are capable of 360 degrees B axis rotation, to machine parts in the main or sub spindle. Main and sub spindles are both built in with MP Scale C axes construction that helps in obtaining higher spindle rotation accuracy and better surface finish during the cutting operation. Both the Y axis turret and Y axis slide can machine on main or sub spindle, delivering the capability to pinch, turn or mill on either the main or sub spindle.
The new 42mm sliding headstock CNC SwissTurn Diamont 42 SY2B is the flagship model offered by Eurotech. It comes built with the superior engineered Meehanite castings, the very high precision THK/NSK bearings and linear ways and it is brought to us with the recognized leader of multi-axis quality control systems, i.e., Mistubishi. Eurotech's "Win with Technology" Swiss-Type turn/mill machines range from 6 to 11 axes in six models: Zeiger, Kobra, Gepard, Zeit, Blitz, and Diamont. All Swiss Turn models can be set up to accept most major brand collets and guide bushings.
