Direct-Drive Spindles
When machining requires high-speed performance, Troyke's direct-drive spindles deliver precision and control. Direct motor-to-spindle connection eliminates any chance for gear error, allowing for a high degree of accuracy.
January 19, 2017
When machining requires high-speed performance, Troyke's direct-drive spindles deliver precision and control. Direct motor-to-spindle connection eliminates any chance for gear error, allowing for a high degree of accuracy. Available as single- or dual-axis units for machines equipped with linear motors and conventional ballscrews.
Standard Features:
  • · Speed Ranges to 600 rpm
  • · Load Capacity 50 lbs.
  • · Resolution 0.001°
  • · Tilt Axis Range +/-120°
  • Position Feedback:
  • · Renishaw RESM 209 Encoder Ring
    · Fanuc Aicz Encoder Ring
    · Heidenhain RON & RCN Encoders
  • · Barden ABEC 7 Spindle Bearings
  • Standard Torque Motors:
  • · Etel TMB Series
  • · GE-Fanuc DiS Series
  • · Siemens 1FW6 Series
  • · Kollmorgen
  • · I DAM
  • Optional Accessories:
  • · Manual Chucks
  • · 5C Collet Chucks and 16C Collet Chucks
  • · Faceplates
  • · Mandrels
  • · Controls (Single and Dual Axis)
