Double-Clamp
Double-Clamp
Kyocera Industrial Ceramics Corp., Cutting Tool Div.'s double-clamp tool body firmly clamps the insert in two directions with one tightening action.
Kyocera Industrial Ceramics Corp., Cutting Tool Div.'s double-clamp tool body firmly clamps the insert in two directions with one tightening action. The result is enhanced contact between the shim and insert. That extends insert life, improves the accuracy of the insert position and increases machining stability, according to the company.
