![Ergonomic Equipment for Elevated Work Heights Includes Double Scissor Lift & Tilt Table](/sites/default/files/styles/product_image/public/product_images/lift-tilt-convey-raised-shadow.jpg?itok=R9kZTS7y)
Verti-Lift presents a complete line or ergonomic equipment for elevated work heights. In the world of manufacturing and assembly, some oversized products require work to be done at an elevated height. Verti-Lift’s Double Scissor Lift & Tilt Tables allow operators the ergonomic flexibility to work at an elevated work height.
Whether it’s an assembly cell, an automated line or part of a manufacturing process, some oversized products require work to be done in the vertical position. The Verti-Lift’s Double Scissor Lift & Tilt Tables allow an operator to work from an elevated position and platform for greater ergonomic access to the product. They are suitable for panel build and assembly, door manufacturing, furniture manufacturing and assembly, industrial HVAC manufacturing and assembly, file cabinet or locker manufacturing and assembly, or a broad range of other oversized products.
Verti-Lift’s turnkey solution capabilities also include conveyors, and poly-coated rollers for finished product handling and conveyance.
The company works closely with distributors and system integrators to design, build and integrate its material handling equipment into new or existing facilities and production lines.
