Newall introduces the launch of its' DP500 mill and lathe packages. Designed specifically to target the turret mill and tool room lathe market, these packages are priced to meet the needs of the price conscious user.
The DP500 DRO comes with many features such as absolute and incremental readings, radius/diameter readings, error compensation and inch/metric instant conversion. The unit also includes a tool offset library that compensates for different tools' lengths for turning operations. The offsets can be manually programed or they can be entered on-the-fly.
For milling applications, the DP500 includes bolt hole circle routine. Simply enter the data via the message prompts and the DP500 calculates the coordinates of each hole within the circle, saving the operator time and ultimately money.
The DP500 DRO Package is available in two or three axes for turret mills with travels up to 16" (406mm) x 36" (914mm) and for two axes lathes with up to 80" (2M) between centers.
The DP500 packages come with the new Spherosyn LT or Microsyn LT encoders. These encoders feature the same inductive technology and IP67 rating as Newall's Spherosyn 2G encoders and will provide accurate and dependable readings under the harshest environmental conditions, according to the company.
- centers
centers
- lathe
lathe
- milling machine ( mill)
- turning
