DRV Magic Drill Expansion
With new larger diameters finally available, these high-efficiency indexable drills span from Ø0.500"~Ø2.000" and Ø12mm~Ø60mm sizes.Achieve excellent drilling precision with less variation in hole diameter. The DRV's optimal web thickness design creates low cutting forces and reduces chattering for smooth drilling applications.n
The popular DRV indexable Magic Drill family just got bigger! With new larger diameters finally available, these high-efficiency indexable drills span from Ø0.500"~Ø2.000" and Ø12mm~Ø60mm sizes.
Built for Speed and Accuracy
2D ~ 6D Drilling Lineup
Great for numerous high-speed drilling applications, the DRV can tackle numerous jobs in multiple materials with 2xD to 6xD depth capabilities.
Controlled Chip Flow
The DRV is equipped with a CVD outer insert and a PVD inner insert combination to account for different speeds and forces exerted on each cutting edge. The DRV utilizes economical inserts with 4 cutting edges and 4 unique chipbreaker designs for various machining applications.
