![DTE3-020, DTE4-080 and DTE5-080 TungCut Grooving Inserts Added to Line DTE3-020, DTE4-080 and DTE5-080 TungCut Grooving Inserts](/sites/default/files/styles/product_image/public/product_images/TungCut_Expansion.jpg?itok=REaws-qI)
Tungaloy is expanding its TungCut series of grooving tools to include new insert and holder options. TungCut’s DTE grooving insert offers a versatile design that allows the insert to be used for grooving and turning in both axial and radial directions.
The new insert options include DTE3-020 for a cutting width of 3 mm with 0.2 mm corner radii, as well as DTE4-080 and DTE5-080 for cutting widths of 4 mm and 5 mm, respectively, both with 0.8 mm corner radii. The inserts are offered in AH7025, a PVD grade dedicated for grooving applications from roughing to finishing.
The popular modular tooling series, TungModularSystem now includes a CAEFR-****-CHP type modular blade enabling OD and face grooving with up to 4.8 mm cutting depths. The blades are offered in two sizes covering cutting widths from 2 mm to 6 mm.
In addition, TungCut expands the monoblock holder lineup in its TungCut toolholder series to include JCTEL and CTER/L lines to meet various cutting depth needs. This expansion further enhances TungCut to be able to provide optimal cutting-edge overhangs in various grooving situations, while minimizing vibration and instability.
At a glance:
Expanded lineup of DTE grooving inserts for additional cutting widths and corner radii
New TungModularSystem modular blades for OD and face grooving applications with cutting widths from 2 mm to 6 mm
Enhanced monoblock toolholder lineup offers expanded coverage of maximum cutting depths
Total of 23 items to be added in this expansion
- grooving
grooving
- modular tooling
modular tooling
1. Tooling system comprised of standardized tools and toolholders. 2. Devices that allow rapid mounting and replacement of tools. Commonly used with carousel toolchangers and other computerized machining operations. See toolchanger; toolholder.
- outer diameter ( OD)
- toolholder
toolholder
- turning
