Dual Absolute Encoder Versions
Electromate introduces Dual Absolute encoder versions of the FHA-C mini actuator, which feature BiSS-C bi-directional communication for both encoders. The dual encoders are incorporated in essentially the same package size as the long-standing FHA-C mini single incremental encoder version. Without increasing the size, the dual absolute encoder offers single turn absolute position at the output, without the need for battery back-up.
Electromate introduces Dual Absolute encoder versions of the FHA-C mini actuator, which feature BiSS-C bi-directional communication for both encoders. The dual encoders are incorporated in essentially the same package size as the long-standing FHA-C mini single incremental encoder version. Without increasing the size, the dual absolute encoder offers single turn absolute position at the output, without the need for battery back-up. Panel mount connectors come standard, and customers can choose between four exit options.
The FHA-C mini series is a family of extremely compact actuators that deliver high torque with exceptional accuracy and repeatability. The actuator combines a high precision Harmonic Drive gear component with a pancake brushless servo motor. A single-turn, 14-bit (16384 cpr) gear output encoder has been integrated along with a single-turn, 14-bit (16384 cpr) motor input encoder providing a true absolute encoder that does not require a battery within 360° of rotation of the output.
Typical multiple-turn encoders monitoring the motor input shaft require a battery to store the current position when power is lost to the system; however, the dual absolute encoder overcomes this need. In other words, no battery is required. When power is restored the actuator knows its position.
Features include:
• Zero backlash
• Incremental, Absolute or Dual Absolute Encoder
• 24VDC winding
• High-torque/weight and torque/volume ratio
• Optional flex-rated cables with sealed connectors
