Versatile dual-head buffer/polishing lathes from Palmgren can handle the most-demanding polishing applications, as well as fine detailing work. Available in 12” and 16” models, the two-speed buffer provides fast and effective deburring, finishing, graining, surface conditioning, polishing and buffing. Both can easily remove scratches and imperfections to bring out the natural luster of the metal.
Versatility is enhanced by narrow and wide wheel clamping capability that allows the mixing and matching from narrow to wide wheels of different sizes and shapes. The buffer/lathe has a direct drive train with rugged oversized threaded nickel chromed shaft and is designed with additional room between the wheels to accommodate a variety of parts simply and quickly.
- buffing
buffing
Use of rapidly spinning wires or fibers to effectively and economically remove burrs, scratches and similar mechanical imperfections from precision and highly stressed components. The greatest application is in the manufacture of gears and bearing races where the removal of sharp edges and stress risers by power methods has increased the speed of the operation.
- polishing
polishing
