Duracool BR 300 Semisynthetic Cutting and Grinding Fluid
January 26, 2017
Duracool BR 300 from Enterprise Oil Co. represents an advanced technology in biostable cutting and grinding coolants. Duracool BR 300 is a semisynthetic cutting and grinding fluid with a high oil content for machining all metals from high-alloy stainless steels to aluminum and copper-based alloys.
Duracool BR 300 addresses the problem of multiple coolants in a shop. Duracool BR 300 is unique in that it can be used as a cutting fluid for all machining applications, including severe applications such as aluminum tapping and gundrilling, but can also be used for all water-based grinding applications.
Duracool BR 300 is formulated to be resistant to biological degradation and thus eliminates “Monday morning odors.” Duracool BR 300 has high operator acceptance due to its extremely eco-friendly additive package containing no chlorine, sulfur, nitrites, phenolics, heavy metals or dyes, according to the company.
Duracool BR 300 has the lubricity of a soluble oil and the cleanliness of a synthetic. As a result, Duracool BR 300 maintains exceptional cleanliness of both the interior and exterior of a machine tool. Duracool BR 300 has a heavy-duty corrosion package that prevents rusting on all surfaces of the machine including the toolholders. It also gives exceptional rust protection to machined cast iron parts.
Duracool BR 300 will not foam in high-pressure coolant systems even when exceeding 1,000 psi. Duracool BR 300 is 100 percent recyclable, making it environmentally friendly. Duracool BR 300 rejects tramp oils readily so they can be easily skimmed off either in the machine tool or in an exterior recycling system. There should never be a need to dispose of the coolant reducing disposal costs dramatically.
  • alloys
    alloys
  • coolant
  • cutting fluid
    cutting fluid
    Liquid used to improve workpiece machinability, enhance tool life, flush out chips and machining debris, and cool the workpiece and tool. Three basic types are: straight oils; soluble oils, which emulsify in water; and synthetic fluids, which are water-based chemical solutions having no oil. See coolant; semisynthetic cutting fluid; soluble-oil cutting fluid; synthetic cutting fluid.
  • grinding
  • gundrilling
    gundrilling
    Drilling process using a self-guiding tool to produce deep, precise holes. High-pressure coolant is fed to the cutting area, usually through the gundrill’s shank.
  • lubricity
    lubricity
    Measure of the relative efficiency with which a cutting fluid or lubricant reduces friction between surfaces.
  • stainless steels
    stainless steels
  • tapping
    tapping
PRODUCTS
11/20/2024
10/23/2024
10/23/2024
