![](/sites/default/files/styles/product_image/public/product_images/1003-E-Z.jpg?itok=WRSIxQfN)
The E-Z Tool Calculator from E-Z Burr Tool Co. offers a simple way to see what tool, blade or insert to order, as well as the recommended speeds and feeds for the tool, which is available at ezburr.com/eztoolcalculator. Users type the hole diameter, shank size, workpiece material, cutting condition and cutting style into the calculator. Results are produced in seconds, including a picture showing the tool specifications.
- burr
burr
- shank
shank
