![](/sites/default/files/styles/product_image/public/product_images/0715-NTUSA_BT-SDM.jpg?itok=dFOC7FPF)
NT Tool's Easy Preset Collet Holders are designed to increase setup speeds and minimize downtime on the shop floor. These SDM holders have a built-in guide ring that can be rotated by hand to adjust projection length in seconds, without sacrificing the holder's high level of precision. Projection length can be adjusted easily even while measuring height, allowing the target value to be reached with ease.
Like many of NT Tool's collet holders, the SDM utilizes 12° taper FDC collets. By using a more gradual taper than 16° ER collets, FDC collets grip the cutting tool more evenly, increasing gripping force and reducing slippage. This also allows FDC collets to provide runout below 5 µm, whereas ER collets can only guarantee 10 µm. Metal-sealed coolant-compatible FDC collets have the added benefit of working without sealing rings, further decreasing downtime for routine setup and maintenance.
SDM holders are available in HSK, CAT (standard and two-face contact), BT (standard and two-face contact), and UTS shank styles. Standard collets cover a wide chucking range (0.020" to 0.866" in diameter/0.5mm to 22.0mm), and custom sizes are readily accommodated.
The Easy Preset system is also available for NT Tool's STM Tapping Chucks.
- collet
collet
- shank
shank
- tapping
tapping
