EcoShield Heat-Sealable Paper
Cortec has made it easy for industries to create their own custom-sized recyclable bags and envelopes with EcoShield heat-sealable paper. Whether a company needs to manufacture its own standard or custom bag for a specific product, or whether extra wide paper is needed to make paper bags, sleeves, or envelopes on demand, EcoShield heat-sealable paper is ready to use.
January 26, 2017
Simply cut the paper to the desired size; fold and shape into an envelope, sleeve, or bag; and apply heat to seal.
EcoShield EcoShield heat-sealable paper is coated with a water-based heat sealable adhesive coating. When the coated sides are placed together and heat is applied, the paper seals and forms a bond that is stronger
than the paper. The paper is nontoxic, fully repulpable, and readily recyclable, making it ideal for environmentally friendly disposal considerations. These properties also make it suitable for packaging situations where a product can be left in the bag and thrown into application conditions that will disintegrate the paper.
EcoShield heat-sealable paper comes in large stock rolls of 600' (182.88 meters) by 36" or 48" wide (1-1.22 meters), with customizable widths available up to 68" (1.73 meters), making it easy to construct standard or custom envelopes, bags, or sleeves in a variety of sizes. The paper can be printed with product identification and details
before assembly.
EcoShield heat-sealable paper conforms to the following test methods: TAPPI T-410 (Basis Weight), TAPPI T-411 (Caliper), TAPPI T-452 (Brightness of pulp, paper, and paperboard), and ASTM F88-99 (Seal strength of flexible barrier materials).
