EcoSonic Electronic Cleaner and Protector
An electronic cleaner/protector from Cortec's EcoSonic line is powered by Nano-VpCI, which reportedly provides instant, long-term, multiple-metal corrosion protection. This new protector is designed to fight destructive effects of corrosion of complex, sensitive electronic and electrical equipment.
January 26, 2017
An electronic cleaner/protector from Cortec's EcoSonic line is powered by Nano-VpCI, which reportedly provides instant, long-term, multiple-metal corrosion protection. This new protector is designed to fight destructive effects of corrosion of complex, sensitive electronic and electrical equipment. More importantly, it saves money by reducing labor time, extending product life, and eliminating downtime due to corrosion.
As a multi-metal, multifunctional outdoor cleaner and corrosion inhibitor it protects vulnerable electrical or electronic components exposed to moisture and other aggressive environments. EcoSonic cleaner is especially intended for protecting outdoor electrical connections and can be applied as a light mist after final assembly or in the field. With moisture-displacing and penetrating film characteristics, it serves as a suitable contact cleaner of oils, grime and other contaminants.
