EIV5 Series Endmills
April 27, 2016
The EIV5 series from Millstar is revitalizing conventional practices for machine shops. With its combination of radial grind, variable helix, variable pitch and radius preparation, the EIV5 is a versatile endmill engineered for diverse machining applications.
Reinforced cutting edge allows increased chip load without risk of edge failure.
Variable pitch accommodates large step-overs with no bottom vibration.
Variable helix eliminates side vibrations while achieving greater DOC.
Corner radius preparation allows longer machining times without radius failure.
Exceptional performance with high-temperature alloys like titanium at 300sfm 2xD with 20 percent step-over and a 0.6 percent chip load.
  • alloys
    alloys
  • endmill
    endmill
  • pitch
    pitch
  • step-over
    step-over
    Distance between the passes of the toolpath; the path spacing. The distance the tool will move horizontally when making the next pass. Too great of a step-over will cause difficulty machining because there will be too much pressure on the tool as it is trying to cut with too much of its surface area.
