Elbo Controlli Khyan TW Presetter
KOMA Precision has introduced the new Khyan-TW hybrid Tool Presetter.
KOMA Precision has introduced the new Khyan-TW hybrid Tool Presetter. This tool presetter was developed as a more cost effective equivalent to competitor tool inspection machines. Constructed using ground granite and stainless steel with a single 23" High-Definition screen the unit has two outstanding optical cameras that also sport impressive digital zoom capabilities and users can import and export dxf profiles to check and compare tools. Easy to set-up and simple to operate the unit even incorporates additional capabilities focused specifically on tool geometry.
The precision spindle system is fully interchangeable and uses a one-piece cartridge which eliminates the need for adaptors and any associated errors that they lead to. The spindle on the Khyan-TW also incorporates an innovative universal mechanical clamping system with its own electronic tool clamping confirmation.
The software provides a complete tool management system and working with your DNC system it can convert measured tool data in to CNC code for direct loading in to the machine's controller. For added convenience the system comes with Wi-Fi connectivity as standard.
