Eldorado M75-30T Gundrilling Machine
The Eldorado M75-30T from Kays Engineering Inc. is a twin-spindle gundrilling machine widely used for the manufacture of orthopedic implants, including femur nails and bone screws.
September 1, 2015
The Eldorado M75-30T from Kays Engineering Inc. is a twin-spindle gundrilling machine widely used for the manufacture of orthopedic implants, including femur nails and bone screws. The machine has greatly improved the accuracy of the components while also reducing the drilling cycle time, according to the company.
The Eldorado M75-30T has a 0.75-inch (19.1mm) drilling capacity and a 30-inch (762mm) drilling depth. It features two drilling spindles with independent spindle control, allowing two different drilling cycles at the same time. The machine also utilizes precision chucks and tailstock counter-rotation of the workpiece to improve drilling performance. Tailstock position is controlled via programmable servo to accommodate different part lengths.
The Eldorado M75-30T features a durable design that incorporates flame-hardened and ground cast iron box ways and hand-scraped spindle housings (versus linear guide ways and milled surfaces). This results in superior vibration dampening, extended tool life, and improved hole accuracy and surface finish. Standard elements are also included on the M75-30T, such as a high-pressure coolant system, Beckhoff controls, and a full machine enclosure.
  • gundrilling
    Drilling process using a self-guiding tool to produce deep, precise holes. High-pressure coolant is fed to the cutting area, usually through the gundrill’s shank.
