Electrically Interlocked Lathe crosslide/carriage travel shields
Rockford Systems Inc. has introduced a new line of electrically interlocked heavy-duty crosslide/carriage travel shields.
July 1, 2011
Rockford Systems Inc. has introduced a new line of electrically interlocked heavy-duty crosslide/carriage travel shields. The use of these electrically interlocked crosslide/carriage travel shields goes beyond OSHA and ANSI safety requirements.
When the shield is swung out of position, the positive contacts on the microswitch open, sending a stop signal to the machine control. The safety microswitch electrical wires are furnished with a protective sheath and connect to the safety circuit of the machine that switches off the control to the movement of the chuck. All safety microswitches are mounted in an enclosed housing with a rating of IP 67 and a mechanical life of one million switching cycles.
The shields consist of a high impact-resistant, transparent polycarbonate front panel with an aluminum top plate that provides operator protection from flying chips and coolant. The adjustable shield attaches to tubular-steel arms that provide additional adjustability at the joint and steel base, and can be swung out of the way for easy access to the workpiece and tooling. The steel base which houses the safety microswitch mounts to the backside of the horizontal carriage of the machine.
