Elevated-Temperature Hard Hat H-700T
In challenging, elevated-heat conditions you need safety equipment that stands up to the heat and helps keep workers comfortable. Designed for workers in industries such as metalworking, smelting and glass manufacturing, with radiant heat environments, 3M Personal Safety Div. has launched the new 3M elevated-temperature hard hat H-700T series.
H-700T hard hats are engineered to withstand radiant heat loads up to 190 degrees Celsius or 375 degrees Fahrenheit. Built with an injection molding technology, the elevated temperature hard hats offer lightweight protection (less than 380 g), and a suspension that sits lower on the head to reduce pressure and increase security. The hard hats meet ANSI Z89.1-2014 Type 1, G standards.
"This series is a perfect example of how 3M's personal safety experts are working to make tough jobs easier," says Steve Bertling, global business manager at 3M Personal Safety Div. "Our experts designed these hard hats—and the additional personal safety accessories to go with them—to stand up to extreme radiant heat while keeping workers comfortable. They've done a great job of taking a safety issue, and building a fully-integrated solution that truly supports workers on the job."
The elevated-temperature hard hat H-700T forms the foundation of an integrated personal protective equipment (PPE) system for high-heat environments. The result is a simple solution to help keep workers safe and comfortable on the job.
