EM-O Compact Mist Collector
The EM-O Compact mist collector from Camfil APC is an affordable option for smaller machine shops looking to provide a cleaner and safer work environment. This plug-and-play, small-footprint mist collector separates either oil or synthetic coolant mist from the air before it is inhaled by operators or settles on machines, floors and other surfaces.
The EM-O Compact mist collector is simple to integrate into machine tools. It can be mounted on top of the equipment or on the floor next to equipment as a stand-alone device.
Machine operators can easily convert the EM-O Compact between oil and synthetic mist collection because the same basic filter elements are used for both. An optional HEPA after-filter can be mounted on top of the unit.
The EM-O Compact mist collector features:
- Compact construction
- Maximum filter area
- Full lubrication applications
- Selected minimum lubrication applications with 470-700 cubic feet per minute air volume
- >F9 separation (filtration) efficiency with optional HEPA filter
- Long service life
- Quiet operation
- Easy filter replacement without tools
- Energy efficiency
