ETFR-CHP Toolholder for Face Grooving
Tungaloy Corp. announces the expansion for EasyMultiCut, the multi-functional tool series for grooving: the ETFR-CHP toolholder for face grooving with a coolant hole for high-pressure internal coolant supply. EasyMultiCut features a unique self-clamping insert that provides high tool rigidity.
The toolholder has no top clamping parts to hold down the insert, so smooth chip evacuation is possible in deeper grooving applications. Thus, EasyMultiCut delivers outstanding productivity even in face grooving operations where chip evacuation is usually difficult.
Also, the toolholder has a coolant hole, therefore ample coolant is constantly supplied to the cutting edge, achieving stable and long tool life.
Main features:
■ Applicable for face grooving with groove width 0.157" (4 mm); ø1.181" to 19.685" (ø30 to 500 mm)
■ Maximum groove depth: 0.984" (25 mm)
■ Excellent chip evacuation allows high speed machining, leading to incredible productivity.
