Evolution Magnetic Drills and Circular Saws
Now you can cut through mild steel up to 4 times faster, without heat build up or burrs…and less secondary re-work with KBC and Evolution's Circular Saws and Magnetic Drills. Accessories available for Evolutions Magnetic Drills include: step drills, countersinks, mini cutters, annular cutters, and carbide tipped annular cutters.n
May 26, 2022
KBC Tools & Machinery is pleased to announce that it is now carrying and stocking the Evolution line of heavy duty Metal Cutting Power Tools made especially for metalworking in both Canada and The US and featuring Magnetic Drills and Circular Saws.
KBC stocks Evolution's 1.1/8" and 1.5/8" Magnetic Drills with 2,860 lbs./f of magnet adhesion, ½" drill capacity, 2" maximum cutting depth, ¾" cutter shank, 10 amps, drill travel of 11.1/2", 8 ft. rubber power chord. The Magnetic Drills also come complete with a coolant system to keep your cutting edges cool and sharp, tri-spoke spindle handle, dovetail slides, and a 2 stage magnet which allows you to precisely configure the machine for a perfect result. At only 26.5 lbs. these are light weight while still being heavy duty magnetic drills, and at a super affordable price in comparison to other magnetic drills in the market.
KBC also stocks Evolutions's 7.1/4" Metal Cutting Circular Saw – one of the lightest circular saws on the market to get the job done. The Metal Cutting Circular Saw features 0-45" bevel capacity, adjusting rear paddle lever to set the base plate in a higher position giving a cupping caput up to 2.1/2", 10 ft. power chord, channeled air flow and glass sight shield ensure you always have great visibility of your cutting path, included parallel edge guide to make sure you are cutting straight, a mild steel blade that has fully hardened body plates with 40 tungsten carbide teeth that generate almost no heat, sparks, or burrs – that keeps your teeth sharper for longer resulting in more cuts and a great workable finish with virtually no heat, burr, or sparks.
  • circular saw
    Cutoff machine utilizing a circular blade with serrated teeth. See saw, sawing machine.
