![F-712.PM1 High-Speed Optical Power Meter Offers Wide Wavelength Range F-712.PM1 High-Speed Optical Power Meter](/sites/default/files/styles/product_image/public/product_images/PI_042018.jpg?itok=J5Q1oc3d)
The new F-712.PM1 high-speed optical power meter from PI (Physik Instrumente) converts optical signals and currents of photodiodes into a high resolution, logarithmic analog voltage signal. Its high bandwidth of 20kHz enables faster optical alignment, when used in conjunction with PI’s high-speed FMPA photonics alignment systems for SiP (Silicon Photonics) applications. The extended wavelength range of 400nm to 1,550nm allows working in both the visible and infrared range without switching.
The optical input is designed in a way that eliminates the influence of the optical fiber location in the connector on the optical signal. In addition to the optical input, the device also has a current input. For example, a photodiode can be connected to this input and the diode current converted into a logarithmic voltage signal. Switching between the inputs is done via a button and an LED lights up when the current input is activated. The precise, logarithmical output signal is suitable for optical alignment systems, which is important for fast photonics alignment.
Features
- 20kHz Signal Bandwidth
- 85nW to 85mW Dynamic Range
- 400 -1550nm Wavelength
- 0 - 1mA Input Current
- Logarithmic Output
