Fairlane Urethane-covered Bearings
Fixtureworks offers Fairlane Products Urethane Covered Bearings.
Fixtureworks offers Fairlane Products Urethane Covered Bearings. Available in stock, ready to ship with no lead time, no minimum order and no tooling required, they are available in both inch and metric sizes. This is counter to traditional availability of these types bearing rollers, many of which require lead time, minimum orders and tooling. They have a smooth urethane surface that is cast directly on a precision sealed ball bearing. Not only are they smooth and provide for quiet and non-marring operation, they also provide excellent abrasion resistance and durability.
The inch and metric sizes are offered in two styles, single bearing and double bearing. The single bearing style is available in diameter sizes from 0.750 to 3" and from 20 to 70mm. Widths range from 0.196 to 0.563 in and 5 to 12mm.
The double bearing style is available in diameters from 0.750 to 3.00" and 20 to 70mm, with widths from 0.392 to 1.125 in and 10 to 24mm. Durometers are available from 35 to 95 in both inch and metric sizes.
The urethane covered bearings are also available with stud mount. These covered bearings also have a smooth urethane surface. They come assembled with a button head cap screw, spacer and locknut for easy mounting. The stud mounts, also available in metric sizes, are available in diameters from 0.875 to 2.00 and 20 to 50mm with stud sizes ranging from ¼ to 5⁄8" and M5 to M12, durometers from 35 to 95.
