Methods Machine Tools Inc. has announced they have introduced the new FANUC RoboCut. C400iA and C600iA wire EDMs. These EDMs include several important upgrades including the new FANUC 31iWB Control which is loaded with new features for improved accuracy and finish, especially in high-taper 4-Axis cutting. The Ai Pulse Control II now offers better straightness and faster cutting speeds for both roughing and finishing in interrupted cuts. And the FANUC Auto-Threader offers enhanced reliability, including when threading soft wire while submerged and in the cutting gap.
"The C400iA and C600iA lines provide our EDM customers with the latest in proven FANUC technology with major upgrades to optimize productivity," said Mr. Stephen Bond, National Sales Manager for FANUC RoboDrill, RoboCut and EDM Products, Methods Machine Tools.
The new FANUC Wire EDM Series also features several new control enhancements designed to reduce overall operational costs by monitoring electrical component usage for minimizing power consumption. Costs are further reduced with the new "Eco Mode," which reduces wire consumption up to 30 percent. And the PCD power supply has been upgraded to allow for more efficient burning in difficult-to-cut materials such as CBN and some carbon fibers. Also, cutting technology is available for machining complex, detailed graphite electrodes up to 6 inches thick with a super fine finish. Significant upgrades have been made to RoboCut Link i cut monitor software that is standard on RoboCut machines for monitoring and operating the machine remotely.
A new user-friendly interface is now available for Apple iPad's and other remote smart devices. Like the FANUC iE and iD EDMs, the new FANUC RoboCut C400iA and C600iA wire EDMs are capable of manufacturing complex components and offer seven-axis simultaneous machining as an option.
- burning
burning
Rotary tool that removes hard or soft materials similar to a rotary file. A bur’s teeth, or flutes, have a negative rake.
- cubic boron nitride ( CBN)
- inner diameter ( ID)
- polycrystalline diamond ( PCD)
- threading
threading
- wire EDM
wire EDM
