FastGrind CNC tool and cutter
The FastGrind CNC tool and cutter grinder from ANCA Inc. is for resharpening tools from 0.35mm to 12mm in diameter. The $120,000 machine uses a double-ended HSK 40 wheel spindle to enhance flexibility and reduce setup time, according to the company.
The FastGrind CNC tool and cutter grinder from ANCA Inc. is for resharpening tools from 0.35mm to 12mm in diameter. The $120,000 machine uses a double-ended HSK 40 wheel spindle to enhance flexibility and reduce setup time, according to the company. The maximum wheel diameter is 8". A part probing system is standard. Ballscrews drive the linear axes and the two rotary axes are direct-driven. All axis saddles are made from a single-piece casting to enhance rigidity and reduce vibration, according to the company.
