The new FIPALIFT tube lifter series from FIPA Inc. represents the integration of all functions, ranging from picking to transporting and target placing. It is a matter of course that each part was developed with a focus on maximum optimization: The manually guided lifting systems enable the gripping of highly diverse and also bulky goods with high weights for the complete physical relief of manpower. As an intelligent supplement, FIPA also offers complete crane systems with aluminum characteristics. The high level of modularity and compatibility of all components in the FIPA standard spectrum paves the way for the rapid, professional processing of projects.
This in itself is innovation across the board, but is by no means all provided by FIPALIFT. FIPA knows what's important, not only with wood processing but in general production and logistics: The rapid, simple implementation of automation projects without complex training of employees and without difficult-to-master interface complexity. The calculation also has to work out with investment and operating overheads.
- relief
relief
