FKS Centrifugal Disk Finishers
Rosler Metal Finishing introduced the FKS Centrifugal Disk Finishers.
May 13, 2013
Rosler Metal Finishing introduced the FKS Centrifugal Disk Finishers. Equally effective for products ranging from .2 to 150mm, these vibratory finishers are reportedly ideal for deburring, surface grinding, and radiusing as well as polishing stampings, castings or machined parts.
The FKS's rotating spinner and stationary work bowl design prevents parts from sticking and guarantees uniform results in shorter process times. Our wear-resistant polyurethane bowl lining ensures long life even under the most challenging conditions. Highly sophisticated sensors provide machine function and gap monitoring for optimal performance and efficiency.
Plus, FKS models are designed to be easily integrated into existing process lines. A central PLC controller manages auxiliary functions such as parts loading and post finishing treatment. Process parameters can be customized to meet specific process requirements such as spinner RPM, water levels and screening times.
  • surface grinding
    Machining of a flat, angled or contoured surface by passing a workpiece beneath a grinding wheel in a plane parallel to the grinding wheel spindle. See grinding.
