FM (Ferro Max) Cold Saw Blades
The Kanefusa single use saw blade technology is reportedly superior to other sawing concepts both in economical and environmental perspectives. The FM (Ferro Max) cold saw blades (single use) cut on average three times faster than a conventional bandsaw or metal saw, which means one machine can do the job of three, reducing power consumption, exhaust emission and mist oil in the air and floor space, all good for the environment.
December 6, 2016
FM cold saw blades also allow a thinner kerf than resharpenable types, which leads to a better material utilization and less swarf that must be either disposed of or recycled. Because all Kanefusa FM Cold Saw Blades are manufactured in Kanefusa Quality, all blades provide a constant cut quality and durability, providing high process reliability, which is a key to "just-in-time" production.
The single-use sawing concept is efficient and highly economical, according to the company. It allows you to use your resources in the most efficient way. You can also reduce manufacturing costs and respond faster to your customer's needs.
